... the charge pipe routing will stay the same and will only require either a short length of Silicone pipe as the turbo outlet is more over to the nearside and possibly an elbow with longer legs to connect to the existing Chargepipe system, I already have a Forge FMIC fitted so thats the charge side taken care of...
seen this discussed quite a few times as well
with the time and money spent swapping it for a K04 versus the time and money spent for swapping it to a Garret GT28, then of course the Garret is the way to go due to the sheer performance you will get from the garret and prob not alot more money to do
changing the K04 is not exactly a straight job and it makes more sense that if you are going to do all of that work, then why not upgrade to a much bigger turbo and get alot more bang for your buck?
Cost will be 1 thing...
How much for a 2nd hand K04 setup (turbo/mani/injectors/piping etc)...£750ish?
How much for a new garret GT28 setup? I have no idea but id imagine even the eliminator kits at 3 times this amount. If going proper BT your speaking 4-5k
GT28 will be laggy compared with K04, will have more grunt but for the £££ i think K04 is a good solution if your not wanting to spend a few £k going proper BT.
280bhp/300lbft from the K04
Internals on this engine good for about 320bhp/320lbft (i think) so its pulling quite close to that.
AMK and BAM a bit more at 350/350 (20mm pins vs 19mm)
Fit an eliminator turbo and you'll always be wondering when a rod is going to let go?
I would be cautious with regard to the downpipe as there is a possibility of it making contact with the charge pipe which runs down the side of the engine to the pancake pipe as obviously 210/225 engines have their charge pipe over the top of the engine for this reason. The 3" downpipe will require quite a large bend to come out of the turbo and go down so space may be tight.
If your doing it yourself then it would be nice and cheap but if your getting a garage to do it you maybe better off with a new k03 housed turbo. You can get k04 turbo and parts dirt cheap, in fact all the bits would cost you less than a new garret turbo id say.
