time line of the last 10 months on my fr
gazjones
no its being fitted tomorrow aft at work should have got the vrs roll bar earlier and had it put on at same time as subframe needs lowering to fit it
how much you looking for it send me a pm if you want
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
i lowered my subframe to fit the vrs ARB and it still wouldnt come out it was a biach!only had 30mins to get old 1 out and new 1 in and run out of time! just couldnt route it out! so gave up for the extra 1mm! also you may need to consider your exhaust as that might start knocking on your rear axle on the brake pipe braket if you lowering it 30mm and is a c**t to get it to stop but mines lowered a tad more so you might get away with it
gazjones
yours is also extened out a bit further which would make it rattle a bit more. the exhaust isfine on fr with 30mm drop and dont have rear passengers!!!!
vrs is 2m thicker than mine so worth it on mine but not really on yours
rashcupra
Oct 15, 2006
6,517
crawley
yer will make a good diffence on yours but 1mm :no: just anouther mod to list i spose :lol: yer i wuda thought you dropping yours 30mm will be fine but il gewt a pic of how close mine is its about 2-3mm on the top and about 4-5mm space to the axle :lol: no passengers for me :lol:
gazjones
well suspension is fitted looks great lowerd 3cm at front about 2-3cm at the back
but silly bloke at work, doing the work broke my arb link so cant test the handling out yet, broke the thread clean in half doing it up with air gun the twat!!!!! so gettin g thagt sorted tomorrow i hope
gazjones
thats a before pic and with a new tyre not bald like on in lowerd pic lol
Triple D
Car looks good gaz, i just hope they have installed them right. The things i see at work with toss pots who fit shocks wrong and use mole grips to clamp the piston when doing them up :ban: Hopefully once you get the ARB sorted you can give them some stick, and they will beable to take it :D
You know how much stick mine got :lol: and they were still working a treat up untill i crashed mine :(
rashcupra
Oct 15, 2006
6,517
crawley
broke the drop link :doh: when you give the car some stick it should bed them in a little to so should go a tad lower but it looks so much better not a 4X4 now :lol: good job mate!
gazjones
cheers peeps cant wait to get drop link sorted but tbh it rolls as much as before and thats without a arb!!!
tyres going on tomorrow as well lol so will take pics when i clean it to show b ack and side view
gazjones
not got rear strut brace yet but drop link sorted today and newish tyres on the front. first impressions are good very flat cornering and when braking and accelerating car dosent lift up or drop anywhere near as much as before!!!!
gazjones
replaced the other drop link today and repainted the calipers, if weather is good ill get some pics up of it clean to show the drop better
