b21playa
oil burner
Jan 10, 2005
544
Birmingham
seen this one beeing sold http://www.opelinfo.com/
ive managed to download the software v1.95 but i need usb_io.dll
anyone tried this and got it working?
says it will do SEAT's up to 2004 with vdo dash.
im using v1.7 at the moment and it sas if you get access denied, to keep trying, but only once in a while do i see the SEEDING message
any ideas
1.7 and anything below definitely won't get the codes from your car. I tried the exact same things as you and couldn't get the code out. I also had the same error for version 1.95 of vagtacho and couldn't fix it, maybe it's different drivers.
rekon its worth getting a v1.95 kit?
spoke to opelinfo and v1.95 gets that error as its a chinese clone and not original
why not spend the time emailing dealers within say a 80 mile radius asking if they will supply the code for you. Then drive there and pay them if you need to. It'll save chancing it buying kit that probably won't work for your car.
cheers
ive emailed all the local ones (25miles), will try further afield
BTW are the 2002 leon tdi's CAN BUS and/or have the immo3 unit?
i would rather have the stuff to do itmyself andoffer the sevice to memeberswho are also having problems retrieving their SKC which would help pay off for the unit
