So does an LC have ESP as apposed to the LCR which we know does!
Has anyone in a LCR tried this??I watched fifth gear one night (there really was nothing else on tv!) and little old Jason plato was throwing a TT round the track and complained that even when he switched the tc and esp off they were still on in the back ground.
Tiff then pops up with the "well if you hold the button down for 10 seconds it disables it completly.
Jason goes back out and tiff was right!
This is/was on the new 2006/7 TT - so might not work on the old MK1's but worth a try.
Good luck.
I would be interested in trying it but offshore just now!!![]()
I'm getting pissed off that the car (with esp off) won't let me accelerate
when the steering wheel is turned. If this 10 second thing works it could be my salvation!!
Not looking to permanently disable but looking for a way to switch off totally that can be switched on again at some point.I've tried this and it doesnt work. However if you press and hold the ESP button the light comes on and eventually goes back off after approx 12 seconds. Unfortunately this means you are back to square one with the ESP on
Perhaps there is some trick to doing it...I have heard though it can be permanently disabled via VAGCOM.
Someone mentioned this can be done during mapping??
Can someone give me any more details about this??
Do you not find that the car doesn't allow you to accelerate around corners?I obviously don't drive hard enough (or bad enough?), as ESP has never proved a problem for me. It gets turned off when I'm going for a more spirited drive but doesn't get in the way of making good pace.
not that I can see, it's not controlled by that ECU, so it won't make any difference
you could go changing a load of settings in vagcom, but given that you won't know what you're doing, and would be guessing - I'd just learn to drive a bit better
Maybe I have a fault
Yup, I drive like you said but its the bit where I want to accelerate out of the corner while still steering a bit that doesn't happen.No, because I was always taught to go into corners slower (not slow, just not flat out), keep a constant pace and then accelerate out of corners for maximum speed and control. Going in flat out and hoping for the best can actually work out slower. At least, that's what I was told years back so I could be very out of date....
What tyres and tyre pressures are you running?
Aye, but thinking now that it might be linked to how much I'm steering!!Tracking / Alignment OK? And I assume you feather in the power progressively?
