N249 bpass and Over BOosting
Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
Right well my car has C as standard!
So will get an F!!!
Driving today on the motorway was alright most of them time, but sometimes, putting your foot down in 5th it would go to limp mode and its LIMP 0 PSI mode!!!!! its defo not 5psi!!! Wouldn't go anywhere at all when putting foot down!!!
this is doing my nut in now!!! Someone must no the answer? Is it just a case of trying the F N75 replacement and hope for the best :(
ian_cupra
i had the same issue, bought a ecs racing n75 valve from tts, and all is fine now.
ian_cupra
it used to be fine, then sometimes when you boot it, it just goes into limp mode 5psi, then other times go to 0psi,
doesnt do it anymore!
as for my setup, basically most the usual stuff, fmic, tip, bypassed the n112, n249, dynatwist, ecs race n75, 007p DV, and a map.
might have another race n75 valve too :)
ian_cupra
waiting on reply from funkyfin2000 first phil. if he doesnt want it i'll let you know, you going to gti inters??
ian_cupra
just looks the same as normal, just in a brown case instead of black, lol, comes with a sticker on it too, that you might wanna peel off, you'll see why when its comes, lol.
fits exactly the same as a normal one
Funkyfin2000
Oct 6, 2005
2,477
excellent, lets hope it stops this charge pressure error!
i had surging issues before the map as well , then worse with the map, done the n249 and doesn't surge but now goes in to limp mode 0 psi just randomly when your flooring it....
£75 all in from TTS inc the G2 engine temp sender and flange!
