HarveyGTI
but like i said jabba map to how cool the engine stays and i have done lots of coolant mods and have a custom FMIC which has taken all the restrictions out and shortened the piping.
you could change every physical pipe, bolt and nut on that car to enhance the performance
the K03s simply cannot flow that amount of air to get that sort of power, the modifications you have "around" the turbo are good, but only to a certian point, but you will still only get so much
why do you think people upgrade from the K03 to the k03s...so to get more power, as the turbo is only capable of flowing so much air
why do people upgrade the K03s to a GT28rs or similar, as the K03s is only capable of so much power i.e. 250bhp
its a physical restriction and mods can only help so much, but still the physical dimensions of the turbo equate to what power the car can put out, and in this case a K03s will never make a figure of 260, regardless of what other modifications are in place
) - bearings fine, compressor blades fine..... turbine housing
Your right, everyone here is talking crap
