str8ballin
211
Hi every1....... Please help!!!
I need the bolts to join the gearbox to the engine but I cant find the part numbers anywhere & SEAT cant help either!!
For Ibiza cupra - AYP engine & EWP gearbox code.
I have ETOS but it only shows regarding the cupra r EDT gearbox.
I ordered some bolts which are underlined below in the image but only the first 2 fit!
Also they only gave me 5bolts, im sure there are 8.
Does anyone have the part numbers I need please! I cant belive even SEAT's software shows the same as my ETOS... nothing about the EWP box[:@]
I will really really appreciate any help.... its stopping me from putting my car together:( ....
Many thanks in advance!
EDT and EWP share the same body housing and yes ETKA does show the same as ETOS
but the answer is listed in your pic ;)
item 1
N10337803 * 2
N10337902 * 2
N90701604 *1
N90743502 * 1
item 2
N90572901 * 2
item 3
N10261302 * 2
i make that 8 bolts and 2 nuts :)
the brackets around the item number means the part is not shown or unable to be shown in the diagram but as there is no listing in model except aluminium they are for all codes - in item 2 there are specific coded bolts for each trans so pick carefully
i think ive listed em right but check just in case
easy when you know how ;)
Thanks so much Fl@pper!
So if i order the items u listed below that should b right?
The longest bolts ( N90572901 * 2) I tried to fit to the engine and they do fit but they are slightly smaller in diameter than the engine holes they fit into...
I assumed they are not right unless thats how they fit!
item 1
N10337803 * 2
N10337902 * 2
N90701604 *1
N90743502 * 1
item 2
N90572901 * 2
item 3
N10261302 * 2
the longer 10mm ones from memory have nuts on the back so look like the go through the engine/box and engine mount at a guess and simply squeeze up
it was very similar on my 16v but the nuts were welded as part of the mounting bracket
check out
main group 1
sub group 99
illustration 199-20
shows the mountings etc there - should help a bit
worth noting a point that nearly all diagrams in ETOS and ETKA show a point of view as though you were looking at the car from the NSF corner
like this angle :
