immobilisers ?
Arosa Steve
114
Sunderland Ish
A Have Been Look For An Alarm/immobiliser for my car so a went in to turners in sunderland and he had a look at my key and said it had a factory fitted immobiliser cos there is a littel black thing on my key.. but to me it looks like it is were the key joins the plastic..
so does any 1 no if it is or if it is not an immobiliser
the car is a 1997 R reg.
Steve
lunalupi
...is not a bloke!
Jul 29, 2006
953
Wiltshire
Yes, it has a standard fit immobiliser :) If you wiggle the steering wheel without the key in, you'll hear it click and lock itself into place
mrcoyote
See no evil...
Jul 26, 2004
2,624
Erm... That's the steering wheel lock not an immobiliser. An immobiliser is generally an electronic device to prevent the starting of a vehicle not the movement.
lunalupi
...is not a bloke!
Jul 29, 2006
953
Wiltshire
Really? I've always heard it refered to as a steering immobiliser!
I'm sure I've been told it has an engine immobiliser too....
Ibiza Monkey
According to autodata CD it should have one (engine code AER). Look for key shaped light on dash when you turn the ignition on.
Gills Fan
165
Isle of Wight
Visit site
The steering lock is in effect an immobiliser as you need to release it to operate the car (via the key). However an immobiliser in general, is often referred to as the electronic device that when armed will inhibit the car to start.
allallyouyou
Arosa Sport
May 23, 2006
292
in therory it can be defined as an immobiliser (the steering wheel lock) as it does in some respect immobilize the vehicle, but no. It is an electronic device that disables the engine if naughty people get in your car! ;)
lunalupi
...is not a bloke!
Jul 29, 2006
953
Wiltshire
I spoke to someone over the weekend, who confirmed they should have engine imobilisers too - if you open up your key, you should find a chip which is what allows the car to start.
If you lose the chip, the car will start, but cut out after about 10 secs...
