The best around is the dension ice link plus. Check out the dension website for more info, easy to set up and use!
do what a mate of mine did with another car.
get a tape converter (a tape with a cable comming out fo it with a jack on the end) then remove the facia and hard wire the cable in behing the faci then in to your glove box. wellaaaa :).
also im pretty sure some guy has cut a hole in his centre consol and has put an Ipod docking station inderneath the plastic and cut a rectangle hole just bige enough for the ipod to fit in to it. and then wired that up to the HU.
The Dension Ice Link Plus will acheive good quality music...but expect to experience problems in skipping tracks.
i.e. when skipping tracks it goes 1,3,5,7,9 and so on.
The only way to play tracks 2/4/6/8 etc is to either let the playlist play, or to skip back a track once its started playing.
IMO, not worth the £100!! And i have one!
I've seen an adaptor somewhere which allows you to have both multi changer and ipod interface connected into the same port at the back of the HU.
