Does anyone have any idea how the outer CV joint is attached to the driveshaft?
I've got the joint out of the hub and cut the old boot off, but I'm stuck.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Cannot be 100% certain on the lc but from past experience on other cars there normally held in with a snap ring or circlip..
Don't know if this is any good, but have a look it's a golf but should be similar, i would have thought...
http://forums.vwvortex.com/zerothread?id=3344208
knock it off with a copper hammer or something similar, its held on with a clip
put the shaft in a vice and give the cv joint a good smack with a hammer ..........
you need to hit the outer edge of cv joint while giving it a pull at the nut end a copper hammer is best to not damage the joint
away from the shaft
