Can anyone recommend a company that does thermal coating..?
I want to get my DP and manifold coated before the new turbo goes in.
i have some unopened heatwrap in my garage if you want itI have decided to go doen the heat wrap road because i will be using my car quite often and i have been told that the wrap will be better for me![]()
i have some unopened heatwrap in my garage if you want it![]()
all due respect bernard... bollox...
massive reduction in radiated temps on my ceramic coated manifold.. not camcoat tho
Bernard
As max says it's all about the speed at which the heat can leave the surface, not about a drop in surface temperature.
The coated manifold will probably run hotter than the uncoated one, but will radiate less heat to the surrounding air. It is not like heat wrap where you actually insulate the surface.
And what determines the speed at which heat can leave the surface ? The temperature, the rate of airflow passing over it and the colour.
We are not changing the temperature much, we are not changing the rate of airflow, we are changing the colour but this does not make a huge change to the heat lost.
I'm still not convinced, any of the suppliers got any data ? Can't see any with actual measurements.
Bernard
according to max's figures, it quarters the speed at which the heat is lost from the surface.
I'd say that was a big difference.
You seem to be missing the point, it can only reduce the speed to 1/4 by reducing the surface temperature by 234ºC. It can't do that with such a thin coating.
Trust me, I've spent 25 odd years measuring heat transfer in a laboratory.
Bernard
