cheers, nice to hear some good things for a change. the most ive seen is 213 but as you probably know it varies on conditions.
Is your airbox smoothed and enlarged?
Looking at the logs you posted, the 'before' log has very few data points so it's hard to spot if there's any mid-range difference, but the peak figure has gone up.
Unfortunately, it's not gone up any more than other people have seen with single airfeeds.
I did wonder, once, about cutting that entire end off the airbox (below the filter line, obviously) and developing it forward to connect to an airfeed, but decided there was no point. It might be worth it if you could get your two airfeeds up to the airbox in parallel.
Looks good mate.
Cant listen to the sound clip as at work
Im sure one can be made 'on the cheap' if its money thats the problem but well done mate....one off mods are awesome and if they work properly its even better.
Dragons Den - here we come![]()
looks sweet Davey, i definately think the CIA is best in that position rather than wedging a pipe around the battery to stock locations.....
Is it all ally Nick? welding ally is a bitch. how will you fix it? remember both mine are on the same fixings as the fogs with the same supports..... i hope you can get it to work for that price![]()
Is this what i need?
EDIT
This is from UK = better
http://cgi.ebay.co.uk/USB-KKL-409-1...ryZ30921QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
