Ive got the Leon FR with the bigger display for bluetooth, does the MFD show a warning for low washer fluid or anything else like a blown bulb for eg ???
maybe it has something to do with having xenons you need washers on the lights? So if you have xenons they warn you otherwise your breaking the law??
Not had my washer fluid low enough to get a warning, will leave it a while and see what happens.
Somebody else told me this week, that if you have Xenons you need headlight washers, I'm 99% sure my Cupra doesn' have headlight washers though...
By law I'm sure it should have them, check this pic out of mine. http://gallery.thatzvinyl.com/d/4497-1/DSCF1440.JPG
Just below the lights they are there, use your washers when you next start the car and see if the lights are wet.
Its a common misconception that "by law" Xenon lights need headlight washers... They do and they don't...
Chris, it is my turn to stand corrected! Thanks for the link... Very interesting and I am personally pleased to see this as it might stop Barry from fitting crappy Fleabay lights and blinding everyone! Actually, it probably won't as Barry doesn't pay much attention to the law anyway!
In my defence (not that it would stand up in court!) I note that the date of that document is 12/06 - the last time I looked in to this was a fair few months before this as I was very worried about this very issue prior to buying the Z... So, Chris you've also made me relieved at selling the Z now... I didn't realise that I was breaking the law.
This will be of news (and interest) on the 350z forums where this issue has been discussed at length... The general consensus was that because it isn't part of the MoT then cars don't need them...
I guess the only real problem - if it still isn't checked as part of the MoT - would be if (and when) you are stopped by the Police and they notice.
Chris - The numeric aspect of your username suggests you may have enforced this law, I'd be itnerested to know if you have. What is the situation when someone is found to be driving without a headlight wash system? Are they given 2 weeks to rectify the situation?
PS Just goes to show how powerful the web is at spreading misinformation! Apols to all for doing that...![]()
I'll get my coat...
May be a bit of a sticky wicket (Keep the coat on Flakmonkey its cold out there
