Advice please! So frustrating!!
Daz_cupra
The Flyin Scotsman
Nov 6, 2007
78
~Montrose~
Hi folks i have tried the search function but im am not coming up with anything for my ibiza cupra mk3.
I need to replace my passenger side dipped bulb as it apperas to have blown. There are a lot of guides on how to do this on a mk4 but cant find any guides for my mk3. (Bi-Focal light by the way)
I think its pathetic that Seat have designed these lights so that you have to go to a dealer to get a bulb replaced. I cant get anywhere near the bulbs as the battery is in the way.
Any guides or help would be much appreciated as my "Local" Seat dealer is 50 miles away!
Daz
:help:
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
yep just the bolts at the base plate and umm yeah...cant remeber if you can undo it and slide the battery back a bit or if you have to take it out completely though. You should try replacing them on a Passat grrr!!
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
I found taking the battery out hell of alot easier than messing about with it in.
Whats the big deal about disconnecting it?
Daz_cupra
The Flyin Scotsman
Nov 6, 2007
78
~Montrose~
well its my 1st cupra and iv never owned a seat before - i just dont like disconencting batteries as i did this on my last car and loads of things were reset and had to program a whole load of things to get the car back to normal
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Time, Date, Trip computer is all that gets reset. Oh and also the ECU but thats a good thing once in a while.
Daz_cupra
The Flyin Scotsman
Nov 6, 2007
78
~Montrose~
ok thanks. Supposidly you have to re-programme the electric windows so that the automatic function works again. so it says in the manual anyway!
truCido
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
I've never had to play with the electric windows to make the automatic thing work again...I left the battery disconnected for quite a few hours plugged it back in and everything was as it was apart from the MPG etc
MikeA
MAF Destroyer
Nov 14, 2005
92
Northants
I managed to change my bulbs last weekend without having to remove the battery. Its a bit fiddely but you can do it.
You just flick the clips off, then slide the cover off towards the side, then you can reach in to the bulbs.
Also, if you do take batt out, it only resets time & date (which will automatically come back through RDS when you switch the radio on) and trip counters. (it does reset some other ECU stuff too but you dont need to worry about that). Windows should be fine.
Mike
Yeh I wouldn't go to the bother of taking the battery out. I managed without having to (doubt it's any different in the 1.4).
If you do take the battery out don't worry about it effing up your electrics. I had mine out for ages fiddling with installing my AMP and it was A ok! Even though mine doesn't have that many electrical eminities (sp.) :lol:
Daz_cupra
The Flyin Scotsman
Nov 6, 2007
78
~Montrose~
thanks for all your suggestions. Think i will have a go at doing it without removing the battery. hopefully wont loose too much skin in the process!!
But i have Only owned my Cupra 3 days and im absolutley loving it!
However, Within 24hrs of me getting my new car, the aerial has been half inched by some F**king theiveing scum bag - these lowlifes make me soooo angry!
Rant Over!
P.S enjoying the site, lots of really useful info on here. allready got my Seatcupra.net Stickers on the car!
Rant Over!
Good man, where abouts in Scotland you from?
