well mate after speaking to jabba if i get my cooling sorted along with having the head done and bigger injectors should be able to run a good amount of power but keep it reasonably clean at the same time
hope they get the smoke to a minimal for you as when im trying to keep up with you i cant see anything and and my CAI sucks of loads of crap.
Is there at Santa Pod also a reaction time in your final 1/4mile time or does the time begins counting when the car begins rolling?
The time starts when your car starts rolling not when the lights go green. Therefore your reaction time has no bearing on your quarter mile time.
This means that I will get a sub 14sec on Santa Pod
My reaction time at the 14.571sec was 1.082sec.
Nope - because the 14.571 clock began ticking when you moved, not when the lights went green. You effectively did a 15.653 from the exact point the lights went green.![]()
What like they did on their own car ???Jabb`s car video
What extra bhp do Jabba say you will have after spending £2000 + on these mods ?
My reaction time was 0.1899 seconds
Oh but I got a reaction time of -0.001 aswell![]()
i thought the injectors were pretty much maxed at 230ish bhp???? am i wrong?
Hi Mate, they have said they will get as much as they can :s lol but mike was telling me that the standard injectors would only be good for upto 250bhp so by changing the injectors i would hope that i would get over the 250bhp mark and with better cooling from this big fmic i would hope that the smaoke shouldn't be as bad because as i have said before the car only smokes when the intake temps get to high... will update when i get the car back but prob wont be for a few weeks...
From what i have seen standard injectors have a limit but like most figures are not set in stone. if just uprating the turbo i would say yes there is a limit of around 230 bhp,but of corse with other mods this can be raised. If tuned to a suitable level with a good map minimal smoke should be seen, If you want the max from your car your going to see excess smoke.
Im going down the route of a vt5, with larger nozzels, hopefully with little smoke, Meaning i will not be getting huge figures.
I am very interested in results seen with polished and ported head. would be good to see some before and after dynos. are jabba just taking a dremel to it or i they performing some flow measurements etc???
Wanting to take my leon down the pod, I am aiming for low 15's.
