Does anyone know about the tyre pressure monitor and what happens if you fit aftermarket rims? i'm thinking about getting bigger wheels but dont want the dash lit up like an xmas tree
It works off the ABS sensors, so as long as all the wheels/tyres are the same size you can do what you want.
The sensor is strapped to the inside of the rim with a metal band. ie the sensor is inside the tyre. Get new rims and you'd have to get the sensors moved.
There is another system - but it is too expensive to fit on most cars. This is where there is a radio transmitter fitted inside the rim, which reports pressure and temp to the cars computers.
was told by dealer that there needs to be a major drop in pressure to activate sensors fitted 19s and had to have sensers reset ( i belive you have to drive straight at about 10mph whilst pressing down the button on console } chris
http://www.seatcupra.net/forums/showpost.php?p=1598386&postcount=19
This info was confirmed by a local dealer's service manager.
That's the system that's fitted to the Peugeot 407. Dad had a tyre on his changed a few weeks ago. The fitter showed him the sensor. Since the tyre change he keeps getting an error popping up saying that the pressures aren't being monitored. Apparently it has to go to Peugeot to be reset.
Interesting post. So basically I should only reset the sensors if something has changed on the car like put new wheels/tyres on?
The salesman told me to reset them everytime I got in the car, but I never did believe a word they told me...
