the front bumper from seat is only around £120 , and say £90 to get it sprayed , dont get a copy bumper , it will never line up as good as a genuine
isnt that tts , the front bumper from seat is only around £120 , and say £90 to get it sprayed , dont get a copy bumper , it will never line up as good as a genuine
Maybe your right, if you get a bumper from seat, does it have all the honeycombe and fog light mounts etc?
Top one is what i'm usure about. Pretty sure these bits are welded in....
And i'm also sure the fog light mounts are the same.
The grill is plastic welded in though yeah? So how the hell do i do that?
To fit the top grille you need to cut the plastic welds off with a sharp blade. If you leave a couple of mm on you can then use a soldering iron to melt the plastic and secure the new grille in. I have done this on my mates cupra with no problems.
