starletcraig
just got hold of a K03s as an upgrade for my mk3 ibiza cupra..
aside from cooler do i need any other mods to run this turbo once its mapped???
cheers craig:)
Exhaust manifold (ATP or similar)
3" DP & 100 Cell Cat & cat back system
Bigger TIP
FMIC
I'd put all of the above on before it's mapped for best results and you'll need a 4 Bar FPR as well.
Depends who maps it to weather or not you would need the 4bar fpr.
2.75" DP is also sutible for a k03s.
you dont NEED another manifold as the k03s will fit on the k03 manifold! so will the standard turbo pipe or forge TIP.
but to get the most you could do with all of the above!
the metal part of the oe tip joining the tubo won't fit iirc as the k03s is a couple of mm larger . you're best off getting the forge tip, I highly recommend it.
