Swany
Just picked up my brand new Leon Cupra tonight and already the Bulb warning light is coming on. I have checked all the lights and they are in fine working order. any ideas why this light is on on the dash???
I also cannot get into the multi function display menu to set speed alert change units time etc. ive tried everything to get into the menu.
Any ideas what could be wrong???
mine does it time after time randomly. Normally if I put my fogs on for a bit on motorway. It should clear itself by the morning.
I will see how it is in the morning!!
Any idea why i cant access the menu on the multi display function??
Bulb light still on this orning i will need to phone the dealer.
Does the Cupra multi function display definetly have a menu part where you can change time change the units set speed alert etc?? can someone confirm please
Yes, I think you hold down the button on the end of the right hand stalk for a few seconds and it comes up with a menu.
The set speed is adjusted via scrolling through the MPG stuff untill you find it, then press OK/Reset and use the up down buttons to adjust it, followed by OK/Reset.
Had the same problem the day I got mine, probably a motor failure in your headlight.....as they perform a check when they are turned on. They move side to side to check the AFS. (i think its called that)
Took 4 weeks for the part to come in.....does the full beam work or does it dip after a few seconds?
If so probably the same problem, a few others have had this.
Yep aint that the truth!, now booked for its third motor change [:@]
Mine had the same warning light. I took it to the dealer who said there was no fault but that something had not been set properly from leaving the factory...they re-set it, and it has not come back on yet six months later
