ibizaTdi1.9
Hi,
I got a very weird problem with my Seat Ibiza, TDI 1.9 (register in 2000). For some unknown reason, the radio will automatically switch on and therefore drain my battery (the engine is off, and key is plug out, the car is locked from outside). It happened a few days ago. I have no any problem with my car before. And today after lunch I checked the car, the raido is on again :-(
Could anyone help?
re ..radio
Hi,
Could anyone help?
hi did you sort out your radio i have a seat ibiza sport year 2000 and 2 days ago mine started with same problem tried every thing so i pulled fuse out while not in use its a pain but it beats a flat battarie i phoned my seat dealer and the said it is a known fault in seat cars with 2000 reg they can repair for £70 +vat its a joke they know about problem they should of recalled all the cars and fix the problem for free !!!!!!:)
Hi 13Roses
Did you manage to get it repaired for £70? I presume this was by only replacing the control unit for the radio, not the entire radio.
I've been told by my dealer that the only option is new radio unit which will cost between £ 280 - £ 500 depending on the actual model I need.
I have seen advertised on the internet a £70 radio repair service. Has anyone used it and was it succesful?
radio
Hi 13Roses
hi seat said they would fix problem for £86 incl vat but when i went and had it put back in they said it was the front part that needed replacing there was nothing wrong with the box at the back so i had to pay £220.12p incl vat because they quoted £86 the said sorry we will not charge u for labour they said u can pay instalments but i payed them i hope this is any use to u :-o
Thanks 13 roses
I will wait for the dealers final quote after they have looked at my car later this week- providing we can get it there. Once there, no doubt the battery will go completely flat and I will have no choice but to pay a massive sum to get it back.
I wonder if the £70 offer on the internet is worth considering.
Thanks 13 roses
it depends what is postage? it my be cheaper though dealer if it is the radio part as i said its around £86 incl vat see which part they say is faulty first like you said i took mine and the took it out and sent it away for 9 days to a repairer they will tell u which bit needs repairing hope yours is the radio part not like mine the hole front bit were the computer screen is :)good luck
Thanks 13 roses, Riko and Darren 200
Am taking out the fuse and this is working- but I can see this won't work long term as I am sure I'll forget one time and come out to a completely flat battery.
After discussion with the dealer they are now offering to send off the radio to a recognised repairer to see if it is possible to rectify the actual fault ( rather than the original discussion which was new radio , full stop) Apparently Seat used to do this automatically as it was a known fault.
going to sound REALLLY strange this but
try it with the front removed but NOT disconnected
had a few early ones that would stick around the tape player buttons causing it to think it was rewinding etc but not actually pushed in enough to make the motors spin
worth a try @ least
i got the same problem! I think that is power problem becouse when car was on radio doesent turn on. Only when car was off, radio powers on!
ANY SOLUTION???
i had the problem and i have wired in a switch to turn it on and off manually nd it is hidden in the ash tray so it looks oem and it can be hidden i could do a guid for you if u like
worth a try @ least
That would be good but mine does it and I don't even have the tape part anymore, modded to fit a regular stereo but the radio keeps coming on by itself. I used to just leave a tape in the player which stopped it but now I want to figure out the circuit so I can permanently disable the stupid thing:D
hi
I have a simple solution :)
put into radio ordinary TAPE :)
then press ON/OFF button, if u want radio ON/OFF
it work very good :thumbup:
Thanks adulka. I have just shoved a tape in and turned the radio off successfully. It is 10,20 pm at night here in Spain, so I need to leave it overnight and check in the morning. Fingers crossed!
Muchas gracias adulka. You are clearly a technical genius! It was fine overnight and continues to behave normally.
I'm lead to believe that The tape in the player simply ensures the buttons to rewind/eject the tape etc are not being pressed at all. It may be a button is sticking, causing it to think its being used.
Sent from my HTC Wildfire S using Tapatalk 2
I got a guy on eBay to repeair mine for £65 got it back in two days
