MauroPT
so what chopping / modding needs to be done to fit the sidelights ?
Now fitting is easy the led´s measure about36mm and 41mm
time to put them 15minutes...super easy!great look!
the sidelights one ? i tried 4 different sidelight Leds and they all stopped after 3 seconds because of bulb malfunction.. so how did you bypass this?Now fitting is easy the led´s measure about36mm and 41mm
u see that white cupra pic
is that indicators???
no its the side lights!u see that white cupra pic
Mauro i dont have msn ! can you send me a PM?
I got these delivered today http://cgi.ebay.com/ebaymotors/ws/e...STRK:MEWN:IT&viewitem=&item=200216875622&rd=1
all fitted took 5 minutes.
Ill post some night pics later![]()
Do any LED's work with out resistors?
these are what i've used in my car. see pics below for effect
http://cgi.ebay.co.uk/M4-Polarg-White-Light-12V-5W-Bulb-Toyota-Acura-Legend_W0QQitemZ250004357850QQihZ015QQcategoryZ28644QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
mine were delivered 5 days after placing order
the photo's don't do them justice. they give off a good white light and look superb next to the Xenon's
They are the same type of bulb as OEM ones (W5W) so no need for resistors when installing LED's although all my interior bulbs are LED and work fine.
Matt
Hope this Help:
But i dont recommend the ultraleds resistors i have ceramic one muche better and dont heat up a lot....![]()
I was looking for some and found these not cheap
Introducing the new PIAA Tera sidelight LED made specifically for European cars which will bring up a dashboard warning light of a blown bulb if using other LED's.
Featuring calibrated electronics, to enable the Tera LED to become invisible to the on board computer system thus preventing the activation of the bulb blown warning indicator. Superb 6500K colour temperature emits a bright eye pleasing light.
http://www.priracing.com/product.php/2293/22/piaa-led-tera-6500k-sidelight-bulbs-euro-cars--pair-
i imagine they will look the same as any old led and a 25p resistor! **** £70 mate mateAnybody using these & show a pic of them lit up ?
