Hello again,
Well i've kinda decided to buy the VAG cable/software and keep a check on those errors. If you remember from earlier on in my post that i was getting these 3 error readings:
16486 P0102 035
MASS AIR FLOW (MAF) SENSOR -G70-
SIGNAL TOO LOW
SPORADIC
17544 P1136 035
LONG TERM FUEL TRIM ADD. FUEL, BANK1
SYSTEM TOO LEAN
16891 P0507 035
IDLE SPEED CONTROL
RPM ABOVE SPECIFIED VALUE
SPORADIC
Well, i've heard a few people saying get them checked out, however, the mechanic at the
garage said that he wouldn't unduly worry about them and if they were the only 3 errors then he would be happy to keep on driving the car without worrying too much.
He said the mpg may "slightly" alter, but with it saying running too lean, that is a minute amount of difference to normal, nothing to worry about.
Is this right ?. I mean i know there will be people on here erring on the cautious side and telling me to get it checked out and that it will knacker the CAT if i leave it. But quite a few have also confirmed what the SEAT mechanic said, not to worry because those 3 errors the VAG test kicked up are fine to leave alone.
That's why i decided to get the VAG cable/software. That way i can check it every week or so and see if those are the only 3 errors. If no more errors crop up then leave it. If more errors work their way in then get it sorted.
Does this seem a sensible approach ??
I'm too worried about the
garage ripping me off, charging me £197 for the lambda probe, then finding the light comes on again, having them do another VAG test and telling me it's the MAF sensor, then the light coming on again.... and so on !!....
I just cannot afford all the expense when i'm thinking of getting a newer Leon Cupra.
What are your thoughts on this approach ??
Could it be better to get the SEAT
garage to check the MAF for me first (as i do think that is what it causing it). Will the SEAT
garage be able to check the MAF BEFORE replacing it ?
Regards,
Andy
