OSIR footrest
soates82
Ordered from zmaxautosport.com in the states, $114 delivered.
soates82
Arrived in the post on Sat.
...Its fitted, but im taking it off and going to use black silicon sealent under it to stick it down better, i used 3M pads and to be honest im not happy with the noise the pads make as they come un stuck, other than that it look ace next to the MK5 pedals i fitted on friday :redface:
Gizzer
105
Hampshire
Out of interest, how easy did you find fitting the Mk V pedals? I've seen the guide elsewhere in the forum but it's always handy to get feedback from people that have actually done it as well.
Brake & clutch look simple enough but it's swapping out the whole accelerator assembly that keeps making me think twice :)
bham_fr
i'm rubbish at DIY kind of stuff, but trust me - it's very easy.
soates82
Brake can clutch pedals are 1min jobs, just remember to slide the lip over the bottom of the pedal first.
Accelerator is a bit more complex, unplug the connector by releasing the red tab and then slide at an angle up and away.
Then prise out the cover of the torx bolt and remove that, after this i spent 20 mins trying to prise it all away, in the end i gave up and gave it a bloody good yank, it broke one of the clips off, but as i was fitting a new one i wasnt that fussed, refitting took less than 2 mins.
The foot rest took a bit longer as there is no room for a drill (unless you have a flexi shaft) so i marked the holes and put pilot holes in using a 1mm drill bit between my fingers.
Gizzer
105
Hampshire
Noooooo! Just went to order the Mk V pedal set from VWSpeed and it's not listed on their page any more :(
Are there any other suppliers out there?
thestonegate
Dan & Khym
Are there any other suppliers out here?
Thats because I oredered the last ones they had last week - Fitted them yesterday feel excellent ! :p
Got the footrest on order too, should receive in a few days...
Super easy to fit!
The accelerator pedal is much softer but more responsive the the original Seat ones. :D
