dbb
Hello, For some time I've been having intermittent problems with the epc system on my 54 lcr. Every now and then the epc light comes on, sometimes with the traction control light as well. These are the fault codes that i get when I hook up the vag-com
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
P1171 - 35-10 - - - Intermittent
17972 - Throttle Actuator (J338): Under-Voltage during Basic Setting
P1564 - 35-10 - - - Intermittent
I've also had
18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
P1639 - 35-10 - - - Intermittent
I have fitted a new pedal, that didn't fix it, today I fitted a new throttle body at great expense and on my way home epc and tc lights came on with just the angle sensor 2 fault code. The optimist in me likes to think that it is just a glitch in a brand new throttle body, the realist in me thinks bugger i haven't fixed it and perhaps i've got a wiring or ecu problem. I would be really grateful if anyone out there could throw some ideas at me.
I've also had
