thing is though at part throttle ,having reached the target power level.. why would it hold boost? as far as the ecu`s concerned youve hit the power level and the throttles not asking for more.
a boost gauge is a must really. it should
help you no end. most take the feed from the pipe coming off the top of the dv. if i was you id make it a permanant fixture.
http://www.seatcupra.net/index.php?option=com_content&task=view&id=500&Itemid=6
im not sure if other vags suffer this... a quick search through audi/vw forums might be worthwhile.
ive only had the leon turbo wise so nothing to compare. but the fact that 1.8ts runs enclosed instead of venting to atmosphere? could that make a difference?
as said i`d not go silly replacing stuff until your certain its a real
problem.
yours happens at 2500rpm ...just as your turbo starts spooling. same as mine at 3k.
the only other thing you could look at is the dv itself... iirc yours is stock? ive found the apr r1 smoother than the forge/bailey piston dvs but the
problem has lessened not vanished. bear in mind over 4 years mines been doing this... its regularly vagcommed and nothing changes. if something was faulty it should have died a while back, especially with the power im running.
mancs is a bit of a trip from brighton lol. but do find a local meet and attend.. im sure people will be happy to give there views on this.... forums are great but nothing more reassuring than someone with experience saying alls well.
