Governor Mod
Ad-mk2Ibiza
432
Boro
www.myspace.com
anyone running a diesel done this?
ive got lots of info about it which someone from here helpfully linked me to.
i wondered if its worthwhile for a start?
what kinda power does it add?
anyone had problems with doing it?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
"A vital component of all diesel engines is a mechanical or electronic governor, which limits the speed of the engine by controlling the rate of fuel delivery. Unlike Otto-cycle engines, incoming air is not throttled and a diesel engine without a governor can easily overspeed, resulting in its destruction. Mechanically governed fuel injection systems are driven by the engine's gear train. These systems use a combination of springs and weights to control fuel delivery relative to both load and speed. Modern, electronically controlled diesel engines control fuel delivery and limit the maximum rpm by use of an electronic control module (ECM) or electronic control unit (ECU). The ECM/ECU receives an engine speed signal, as well as other operating parameters such as intake manifold pressure and fuel temperature, from a sensor and controls the amount of fuel and start of injection timing through electric or hydraulic actuators to maximize power and efficiency and minimize emissions."
You don't want to do that..... running the risk of not being able to control engine speed?
G223
303
Your not blocking out the entire governor though, your makeing the governor cut off later on, in standard, from mid range rpm the governor starts to cut fuel off, doing this mod makes the governor cut in at higher rpm just
Ad-mk2Ibiza
432
Boro
www.myspace.com
thanks mate i tried to explain it to crezz in another thread.
you basically just shim it out a little to get more fuel flow but not too much. yeah you are still running a risk if you do it too much which is why i wanted to know more about it.
and no i dont purchase max power
May 31, 2008
1,247
I wouldnt bother with it to be honest, could spark up a long list of problems. Isn't your 1.9 TD fast enough? lol
