VAC COM Log Advise
waynepixel
Newbie
Aug 14, 2006
135
Kent- Medway
Power runs starting a bit late - from lower down the rev range would have been better ... but
MAF readings look a bit low for Revo Stage 1.
Has the timing being altered with an SPS3 - maybe a little too advanced....
Well I just rang Revo fro some advise about the MAF, and your are right it should be about 180g/s. The guy at Revo did say that my MAf reading might be a little lower because of the summer weather, but apart from that, he was not to sure why my MAF is only putting out 160g/s :cry:
Mr OCD
1,974
Manchester, UK
Very doubtful but your probably asking on the wrong forum...
If your MAF is giving low figures then it probably needs replacing... see if you can try someone elses MAF before buying a new one but then a new one is only £60 ...
waynepixel
Newbie
Aug 14, 2006
135
Kent- Medway
Bloody hell where do you get your MAF from, mine was close to £100 from VW. :headhurt:
waynepixel
Newbie
Aug 14, 2006
135
Kent- Medway
I have been doing some research on the forum about what reading people are getting from there MAF with stage one and stage 2 revo re-maps. I found someone on this forum named B3NNY. He has had a stage 2 revo re-map and upgraded K03s Turbo and allot more modification to go with the stage 2 re-map and the car is producing almost 250-Bhp.
So I looked at some of the longs B3NNY had posted up and his MAF Reading are 180g/s. for almost 250-Bhp. So how can my car with only stage one Revo remap be exspected to produce 180g/s, the numbers do not add up.
http://www.seatcupra.net/forums/showthread.php?t=137077
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
No the numbers don't add up. Take the bhp figures with a big, big pinch of salt. ;)
