Slugger
Can anyone highlight on this diagram where the location of the coolant temp sensor/sender is?
The engine is a 1.9 tdi 110 from a 2002 seat leon.
Many thanks
From reading on another thread it mentioned it being on the right hand side near the MAF? But I couldn't see anything obvious when I had a quick look.
Going to go and explore more now.
Any more help appreciated!
There is also a sender to the right of the engine block as you look at the picture.
Managed to find it quite quickly in the end. Thanks for the input guys. Only problem now is that it didn't solve the issue with the car not wanting to start straight away as though the glow plugs haven't heated up fully.
glow plug relay under the steering wheel?
Right hand end of the block, attached to the coolant pipe Tee, and located underneath the rear pipe, not visible in the picture (good job I've left it on photobucket, eh?). On that picture, the circular vacuum pump is visible at the end of the cam cover: below that, attached to the block, is the metal Tee taking hot coolant from the engine and splitting it to the radiator and the cabin heater (with a bleed off underneath to the oil cooler). Is that where you found yours?
lol, yeah thank you for the use of the picture.
Thats where I eventually found the sensor. Was difficult to see because of the pipe that is right above it.
Your explanation of its location is very good though.
I think the problem may be the fuel pump however, so will get on a do some more searching.
Just changed mine today and it was fairly easy to find, but seeing as I couldn't find any pictures showing the location of this common problem, I took some to share with you!
See my Flickr set for comments....
Nice set of pictures, thanks. You have three glow plugs in the coolant to provide fast warm-up on cold days, something I don't have - but then I only have a TDI 110. I was told they were only standard in cold countries?
Haha, well I didn't even know that's what they were! I'm new to this diesel engine thing, I've been used to a rotary engine for the last 6 years! So are they the glowplugs for the engine? I'm in the UK, and its a 150 Cupra.
no they are not THE glow plugs, they are in the front of the block, in a horizontal line you will see if you take the engine cover off.
Cheers, I didn't think so...normally know my stuff with engines, think I need to read up on diesels!
Sorry to be the cause of confusion.
There will be a single glow plug in each cylinder, providing the pre-heat for cold starting which all diesel engines benefit from.
In addition you have three extra glowplugs (identical, as far as I know, to the ones in the cylinders) which warm the engine coolant up to get the engine to operating temperature more quickly. I don't know offhand whether they come on every time you start, or only when it's cold outside.
As far as I recall the glowplugs for the starting combustion only come into action under a certain temperature, something like 5degrees C maybe? Correct me if I am wrong.
Sometimes when really cold or sitting for a period of time it helps to hit the glow plugs twice before cranking the engine, I find it starts easier and smoother.
