I want the Woosh noise, got a turbo I want to hear god damn it!
Well, it works great :
http://nl.youtube.com/watch?v=ikCXJsI8vzQ
http://nl.youtube.com/watch?v=tStdMKOJqyc
Seriously that is not that loud for all the flack you have copped on here. I have a Forge 007 fitted in reverse (which is 100% safe and still 100% recirculating). Combined with a remap, makes for a seriously loud chirp when i change gear.
To be honest, the noise your 007 made was a bit flat!!!
I don't get you ?
Drove my car with DV007P in full recirc, for 4 years now.
4 years long I have been told it's not possible on our cars...
And been scared off (on this very forum) for engine lights and fault codes ...
Now I thought : what the heck, let's just give it a try ...
I simply disconnected the DV output from the hose and I'm amazed !!
Wish I did that 4 years earlier ...
I have an ear shattering Woosh now ! Finally
And it runs like hell
Can someone with the technical know how explain why it gets dumps back in to the intake, and what will happen if it get's dumped to air like they are doing now.
The air pumped back in does not serve any other purpose whatsoever.
It's just a builtin feature in the ECU as a way of boost-hose leak detection, nothing more than that!
And that's all. Was the easiest way & cheapest solution for VAG, to save production costs
on some real sensors ...
Besides that ,
It is normally dumped in AFTER the MAF !! --> Upstream of it
So the MAF can NOT measure it, like a lot of people mistakenly try to explain over here ...
Only the MAP does. (manifold pressure). A completely different sensor.
That's why you may get fault codes, depending on the software in your ECU.
As long as you know where your fault codes are coming from ,
what would it matter?? You initiated it on purpose when dumping to atmos.
So they are NOT actual fault codes, but an expected result of this action.
In a way he's correct, dumped air is excess boost pressure not used by the engine, the re-circulated air is not measured by the MAF.
Many, many people have been using BOV's on 1.8T's for years with no problems at all, not just 1.8T's, tons of different cars with MAF meters use BOV's with no problems - Subarus, EVO's, Focus RS and ST, etc., etc..
Now who should I believe.....
