1.2 Seat Ibiza won't start
shaheer19
My 1.2 Seat Ibiza 2002 has done 69K and has got some major issues. It was fine till the other day it did start with difficulty and drive but only if you gave it loads of revs. The engine made loud clanking/gurgling noises and cut out after a few mins. I got it home eventually but now it doesnt start and the battery has gone flat....and no, its not under warranty. Anyone know what to do to fix this car?
B3NNO
well im not sure about the loud clanking/gurgling noises, but for a flat battery sounds like your alternator has packed up
RUM4MO
7,839
1,004
South Scotland
posible timing chain slipped
Sorry I hope I'm wrong, but I'll third that - and it's not good - not very good at all. I would have thought that all cars still within the dealer service loop would have had modified parts fitted by now, if you are outwith the dealer service loop then I'd expect if you were getting the car serviced by an indep VAG specialist, then if they did not warn you about this that is not too good, if you service the car yourself then its up to you to make yourself aware of any "new" problems and take corrective action. Either way sounds like your wallet is about to be crunched!
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
I take it you killed the battery from trying in vain to start it ??
As others have said, the no1 cause of this kind of thing is a timing belt tessioner failure, the chain then jumps teeth, one or 2 at first and that makes the engine tough to start and a bit sluggish to drive. When the chain jumps too much you end up with valvs smashing into pistons and a bill for £1k pluss unless you have a warrenty
Good luck, you're going to need it
I think there is more info in the mk4 FAQ bit
StuPDi
old guy
Mar 30, 2007
203
Gillingham Kent
i had a belt jump years ago, the RAC man told me if it wont start in the first couple of seconds, turn the key off and try again
keep on cranking the key for long periods of time is bad news as the fuel pump is whacking in more and more fuel and it's not being burnt due to no firing.
i ended up flooding the engine (something i didn't think was possible with fuel injection :s )
sounds a big job if it is a slipped chain, hope you get it sorted :)
Stu
RUM4MO
7,839
1,004
South Scotland
sounds a big job if it is a slipped chain, hope you get it sorted :) Stu
Stu, was it an Audi V6 engine that you flooded - I did that a few months ago - 2.8V6 Passat, in the end needed preheated plugs + a little oil down each bore + AA starter pack! (Root cause was the changing of fuel filter with a cold engine - happens a lot with Jag+BMW+VAG Vee engines - if you do it with a hot engine the residual heat vaporises the excess fuel and you get off with it, with a cold engine it ends up washing the oil (seal) out of the rings so compression is lost!) You live and learn.
peasie
Sounds like the timing chain has slipped,mine wouldnt rev over 3k dtc showing camshaft sensor error so i replaced this still the same i ended up replacing timing chain but mine had the new longer tensioner fitted 2003 model so i replaced everything anyway timing had jumped reset top dead center using special locking tools and runs perfect now.Good luck any questions i can help with just ask
mixupz
Just call me Rash-MIX
Oct 5, 2007
1,538
Dirty South East London
how easy was it do do your self matey!? mines hitting 30k now and im considering fitting the revised kit and replacing the chain early...prevention is better than cure and all...
peasie
Hi mixupz straight forward to do if you have the correct locking tools 2 lock the camshafts at tdc and the flywheel gets locked as well so it cant really move tools are from laser
Timing Tools - VW 3 Cylinder 4083
Timing tools for Volkswagen Lupo and Polo 1.2 litre engines - 2 and 3 cylinder, 6v/12v 12v tools are OEM T10123x2 and T10121x1 with AZQ/BME engine codes and 6v require T10120x1 and T1021x1 for AWY/BMD engine codes.
Typical Retail Price - £72.28
got them from here much cheaper and spot on next day delivery i paid £47 inc p+p
http://www.bennetts.com/
hope this helps if there is out else you need to know i also bought the haynes polo manual same engine spot on info,steve
tools are £50.99 inc p+p in the uk
this was the cheapest i could find and believe me i am tight as a fishes ar*e
Now can someone please help me with my power steering pump aaahhhhhh!!
