You've probably seen the other thread called 'ambient footwell lighting' as there is a lot of posts in there now, I decided to create a guide to keep things tidy and easily found by other members. Hope it becomes useful
What is this guide?
This will eventually be a comprehensive guide on how to install LEDs in your footwell that will come on with the interior light and dim when the light goes off.
What you will need:
Wire
LEDs of any colour (need to handle 12v)
Nimble fingers
Step 1
Take out your interior light fitting completely and locate the connector housing as shown in the pic below
Remove the connector housing with a knife or screwdriver by levering it out. You will notice on this block you can see numbers 1, 2 and 3. We are interested in numbers 2 + 3, this is the feed your lamp uses when in the flat posistion (or when your lights come on when you unlock your car and open a door)
You will see 3 prongs which you need to tap into. Do this by attaching a few cm's of wire. I would have soldered the wires on but my soldering iron broke so i simply twisted them on tightly ensuring not to short circuit anything. The copper prongs do come out to make life easier.
Next put the block back on and you should be left with something looking neat and tidy.
The reason why I attached the wires to the housing is because it will make things easier, when it comes to running wire from these 'extension points' to the floor. This took me about 5 minutes and is stage one of the process. Stage 2 will be running more wire from the lamp to the floor - i'll do this at the weekend when I have daylight. I have tested the LEDs I bought and can say, once finished this is going to look V smart.
They can be purchased here: http://www.ultraleds.co.uk/u12v60w-white-20000-angle-with-wires-p-1484.html
Step 2 UPDATE
I decided to fit my LEDs tonight as i couldnt wait for the weekend and i'll probably end up busy. So I thought i'd install them. Hiding the wire wasnt hard at all, I simply tucked it under the roof lining and tucked it down the side of the pillar. Basically its invisible!
Here are the results. It's really hard to get a decent pic at night. I tried taking a video of the dimming effect but you can't see a thing.
Interior light on
Drivers side footwell
Passenger footwell
Overall i'm happy with this subtle/practical mod and I would recommend you do the same thing. It doesn't look chavvy at all, and the light isn't too bright either. To put it simply...tasteful.
Get out there and buy some LEDs!
What is this guide?
What you will need:
Wire
Nimble fingers
Step 1
Step 2 UPDATE
Interior light on
Passenger footwell
