sounds good,which controller do you recommend?Turbo is sounding good, car is flying. I say junk the N75.
tut tut,that needle is way over 100mph on a public roadSeems fine on the road , hope my wg aint fooked but i wouldnt be suprised if you see this http://i232.photobucket.com/albums/ee265/caveo/P1000476.jpg
Caveo, what gear did they do the run in at Awesome? 3rd? I think everyone should junk the N75.
N75 is brand new ( wednesday ) take a look @ my RR graph
I am no experts on graphs, but what is going on with that one....it boosts, then tails off and then picks up again?![]()
) - guess this is an N75 issue?
n75 is ok.. what controlling it (map wise) is the issue to hand.
Well my guess is this:
In mid range the turbo is overboosting hence the 1.7 odd bar seen on the boost gauge and 368lb/ft of torque (I hope you changed your rods caveo) - guess this is an N75 issue?
Then presumably wastegate blows open, but shuts again once pressure has been released![]()
I see your point with a correct map in theory providing correct boost, but this doesn't seem to be the case for so many people regardless of mapper.
Over on audi-sport.net I see posts like this all the time. Older engines like mine having more problems.
Both jabba and CC maps on mine have given unsteady boost. EBC for me has been the only solution to keep the boost constant. Whether this removes variables like atmospheric pressure, temp, maf reading??? I don't know how much the OEM bosch ECUs use these things to adjust boost.
I'm happy with my car for the first time in ages.
I think whats evident is the restrictions of the ecu/mapper, making it do things it was'nt designed to do. Older ecu's (Me3.x) have hardware limits which clip your wings more so than on later ME7.x ones..
There's a place for standalone boost controllers, if combined with correct fueling and ignition, but its two independant systems "hopefully" working together mutually well. - "hopefully"
