remaps just fine as std - I drove the 1st one they'd done a day or so after - phenomenal improvement on an already nippy motor
Is the standard DV not prone to splitting after the remap? I thought thats why people changed them??
As far as I am aware, the only ones that have been prone to splitting are the ones on the K03s cars where the DV is located at the hot side of the engine.
There are no performance gains to be had from an uprated valve like the Forge over the standard valve.
Cool. I thought it was the cupras too, so you just saved me some cash if I ever get a map. I was pricing it as map+DV.
Do they sound different, even without the atmospheric spacer?
Revo also do a free trial don't they? That way you can try before you buy.
You can just go straight to Stage 1 as mentioned above, we quote 300 but typically you will see a touch more.
If you go down the Milltek route then upgrade the stage 1 to a stage 2 at the same time for £50+ VAT. From your Revo dealer.
You have probably seen it but here is my Leon with the Turbo back Milltek system, I am loving it, it’s a fantastic package and it’s very very quick!
[/IMG]
[/IMG]
whats included in the turbo back? is that sthe same tailpipe though? wack it on a ramp and get us some pics , i want an exhaust for the k1
Is it resonated or non resonated?
So do Revo still do the free trial on the Cupra? How long does it last and will it affect warranty??
It’s the full system, from the turbo backwards. The tailpipe looks a little meaner than the stock one in the flesh. It has a 200 cell Milltek sports cat too and is resonated. Hot off the press I can now tell you that the system is now available from Milltek. Remember once fitted you can pay the £50 plus vat to upgrade your Stage 1 to Stage 2 at your local dealer if you have Revo Stage 1 already!
I am out visiting dealers over the next few days so will try and get it on a ramp and get some better shots for you all. This is the only roof shot I have so far.
[/IMG]
We do a free trial for 5 hours on the Cupra, it’s around 20% less potent than the full software. The full software has a 30 day money back guarantee so you may as well go the whole hog and try the full fat version!
You can buy a Select+ to turn your performance mode to stock mode before it goes into the dealer if you are concerned. Although the diagnostic system used can not see our software it is pretty obvious if they drive it! Take advantage of the software/switch offer if I was you!
Yes they will know if they drive it, otherwise you will be Ok its the same as the performance software. Current VAG diagnostics will not pick it up. Reflash counters are reset so it doesnt even show there.
BUT they can tell at one point or another that something has been plugged in cant they ??
also does it modify the existing tables of the car software or install a new one?
