jackieboy
I own a 2006 Leon Reference, the tyre pressure warning light came on on Friday, checked the tyre pressures and everything is as it should be. Is there a way to reset the warning light as it seems to be stuck on, I've searched the internet to no avail.
Appreciate any help you can give.
Cheers all.
push and hold for about 5 seconds, the light will flash twice, let go and it will go off.
if it stays on, then there's a fault.
Whats written on the button? not sure if I've seen one there?
And cheers for the replies so far
There is a little icon on it of a flat tyre, the same picture as the warning light. It'll be next to the ESP button/
I'm sorry but why don't people read the handbooks of a new car? all the buttons are clearly explained and it only takes 5 minutes to have a glance at.
I had mine come on the other day, checked and the o/s front was 3 psi down on the n/s, pumped it back up and pressed the button to reset, job done
Seat told me it wasn't done by psi but by "If a Tyre or Tyre's decreases or increases by 10% the light will appear."
