that is probably what the change is i was on about in the pm around '91
I understand.i used to rebuild gearboxes for a living and one of the most common cars we were doing at the time was 2 litre 8v golfs (mk3 gti's) and having owned 4 myself.
when a customer came in and was told the box needed replacing (usually due to diff failing and bits of it making their way out via the casing) if they wanted a cheap fix - not a complete new box then we'd fit mk2 golf gti boxes as they were stronger.
usually the clutch was fine but some (possibly retro fitted) had the smaller input shaft which when you found the clutch to fit the input shaft it was the smaller diameter, it would work fine for a period but would obviously wear alot quicker so was not an option. after some searching and many returned clutches we found a large diameter friction plate which fitted the smaller input shaft.
i only skimmed through the thread so may well have misunderstood, if so my apologies.![]()
I need a bigger friction plate with a small dia splined bore. Cheers.
thought you meant my mrs then - same issues
what size was the one that was fitted.
get the complete kit, 6mm around the edge if you get 212 as opposed to 200mm is really personal preference, it won't make much difference either way unless you are running a high output engine and reaching the limits of the oe item.
Haven't had time to read it all 6 pgs now- but sounds like clutch pushrod has failed. It is on a splined drive and the casting of the pushrod splits opening up the splines and then has no grip hence no pedal.
Either that or the release bearing is dead.
i'd get dimensions/spec on a 1990 mk2 gti clutch and see what that comes up with.
AUG13020.
020300050AX 5 speed manual gearbox 66/18 / AUG From Mk2 Golf listing
66/18 - so a 3.67 diff then
What's the 18 for?
....... and how do we work out which engine types were fitted with an AUG box....?
