I've not heard particularly good things about Jabba. JBS are meant to be better.
My bad! Sorry to guys at Jabba! It's the other way round - heard bad things about JBS - not Jabba! Jabba are good - JBS are bad! Sorry!
Turbo Dynamics do a range of hybrid turbos.
Set 1 - PD130
Stage 1 = MD345 = GT17 compressor wheel.
Stage 2 = MD446 = GT20 compressor wheel.
Set 2 - PD150
Stage 1 = MD374 = GT17 compressor wheel
Stage 2 = MD376 = GT20 compressor wheel
Stage 1 – MD374
Hi flow GT17 compressor wheel, cnc machined compressor housing, 360 degree thrust bearing, cut back turbine blades, lightening of turbine wheel for faster ‘spool up’, modified V.N.T. turbine housing, uprated turbine seals. Other ‘blueprinting’ modifications. APPROX 200 - 220 BHP
Stage 2 – MD376
Hi flow 2275 spec compressor wheel, cnc machined compressor housing, 360 degree thrust bearing, cut back turbine blades, lightening of turbine wheel for faster ‘spool up’, modified V.N.T. turbine housing, uprated turbine seals. Other ‘blueprinting’ modifications. APPROX 240-260 BHP
Stage 1 £925 plus VAT for new unit
Stage 2 £975 plus VAT for new unit
The above prices are quite old now so probably not correct anymore.
So..... I need about £1500 quid for the missus then... keep an eye on the "For Sale" section!![]()
So gonna sound stupid.....Stage 2 for the win? Why wouldn't you? For the minimal price difference.
@S3 AKR If there was ever a post that needed pictures yours is the one.
Yeah stage 2 no point with the hassel and cost else really.
Should arange a SW meet im sure a few peeps will come.
big thing to keep in mind with BT is traction. i strongly recermend a ATB or LSD. Somthink to keep in the back of yor mind wen adding up the cost
will be well worth it onces its all don.
Im sure if traction was an issue, you could get your map tweaked for a few pennies to work the turbo a lot less, lowering the power output??? or just put up with iti would ha.
While I'm waiting for P-torque to get back to me with some prices, does anyone know the part numbers for the PD150 turbo or the PD160 turbo, if they aren't the same as each other? Cheers!
.Im sure if traction was an issue, you could get your map tweaked for a few pennies to work the turbo a lot less, lowering the power output??? or just put up with it i would ha
You can get most of the power down in 3rd > so should be alright.
its not just putting the power down, the handling is massivly inproved as well
