EGR blanked Today!
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
I'm guessing when you say remove the fault you mean permantely map out the EGR and not just clear the fault code?
Yup, just like Kev did with mine. :D
Showed me how he did it on his laptop, map it out completely. :blink:
What a brilliant thread this is, learnt so much! - Wish I had a job like urs Kev.
Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
Jabba - Could you map mine out for me?????
I wouldn't actually mind one your pipes too, buttttttttttttttttttttt i want an SFS hose kit and i have heard there is fitting problems to the pipe of yours......anyone else confirm this?
How much just to map out the error?
My mpg is awful, is it worth me checking my MAF......what block on vag.com is it guys i need to check???
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
No problems with fitting it to the SFS kit at all mate, perfect snug fit, infact its an even better fit as the race pipe pulls the SFS kit away from rubbing on the sharp brake fluid bottle top.
http://www.seatcupra.net/forums/showpost.php?p=2225292&postcount=6
Block 003 - MAF
Block 011 - Boost
I did some logs recently, thats what I got.
Funkyfin2000
Oct 6, 2005
2,477
Thanks dude! thats very useful!
I will log those on a run and see how i get on, my MPG is atrocious....is that with a new MAF.
What MAF figures should we expect on a remapped pd150?
Rich
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Rich
Your MPG is the same as mine, i'm averaging 41.1MPG over 6-8months.
Typical MPG on motorways are anywhere between 36-42MPG, thats driving spot on speed limit too - 70MPH.
Round town I can achieve 40MPG if I watch my instant MPG counter and aim for the highest numbers depending on uphill/downhill etc.
My MAF isn't new, but acording to Ross-Tech a healthy MAF on a standard TDI should:-
  • The MAF is OK if the actual value is at least 850-900 mg/h at 3000 rpm in 4th/5th Gear.
I was hoping that someone else with a Stage1 PD150 would post their MAF readings up, so I can compair and contrast MAF/Boost readings.
Here are my logs in 4th Gear Uphill.
4th Gear Uphill Run 2000RPM-4000RPM - Block 003
Code:
RPM      MAF(S)   MAF(A)   EGR Duty
[COLOR="Red"]2079	850	857.5	4.8
2184	850	1249.5	4.8
2352	850	1249.5	4.8
2499	850	1249.5	4.8
2667	850	1249.5	4.8
2835	850	1249.5	4.8
2961	850	1215.2	4.8
3087	850	1220.1	4.8
3234	850	1195.6	4.8
3360	850	1190.7	4.8
3486	850	1195.6	4.8
3612	850	1180.9	4.8
3738	850	1176	4.8
3822	850	1136.8	4.8
3927	850	1122.1	4.8
4032	850	1117.2	4.8
4116	850	1097.6	4.8[/COLOR]
4200	850	857.5	4.8
3360	850	1234.8	4.8
3360	850	1215.2	4.8
2751	850	573.3	4.8
2688	850	578.2	4.8
2646	850	563.5	4.8
2583	850	592.9	4.8
2541	850	592.9	4.8
2478	850	588	4.8
2436	850	573.3	4.8
2373	850	666.4	20.7
2352	850	676.2	19.9
2310	850	720.3	19.9
2289	850	710.5	19.9
4th Gear Uphill run 2000RPM-4000RPM - Block 011
Code:
RPM      Boost(S) Boost(A) MAP Duty
[COLOR="Red"]2121	2040	1824	45
2268	2652	2820	65.3
2436	2676	2784	63.4
2583	2688	2724	64.5
2751	2688	2700	65.7
2898	2688	2640	65.3
3045	2688	2616	65.3
3171	2688	2616	65.7
3297	2688	2628	65.7
3423	2688	2652	66.5
3549	2688	2664	67.3
3675	2688	2652	67.7
3780	2688	2652	67.3
3885	2676	2628	67.7
3990	2652	2592	67.3
4074	2628	2556	66.1
4158	2592	2532	65.7[/COLOR]
3822	1116	1644	48.6
3360	2688	2724	69.3
3066	1044	1908	43.8
2730	1032	1428	39.8
2667	1020	1356	39.4
2625	1020	1344	38.6
2562	1020	1356	38.3
2520	1020	1356	37.9
2457	1008	1344	37.5
2415	1116	1320	37.5
2373	1272	1452	38.3
2331	1284	1536	38.3
2310	1284	1584	37.9
2268	1452	1608	38.6
S3 AKR
livin' the dream!!!
Jun 30, 2004
1,453
Colchester, Essex
For what it's worth......I used to commute 80 motorway miles to work each day and I tried the whole "sticking-to-the-speed-limit-to-save-cash" thing and got an average of 62mpg (yes.... 62mpg) in my PD150 with revo switched on.
At a steady 90mph (on a private road of a very similar length, of course) I'd get 48-50mpg depending on the weather and the amount of people slowing me down and me needing to accelerate past them once they moved over!
Funkyfin2000
Oct 6, 2005
2,477
thats why the wide differences in MPg really bug me.....i don't think my car is 'right' or very good for a TDI, i often wander what it would achieve unmapped.
the highiest i have every got, thats like 60 for 50miles on a motorway was about 51mpg! that was it, but that was taking it ou of gear on downhills etc!
i don't understand the wide variation we see...
jabbasport
Yes i could do yours for you.
We map out the fault code free of charge if you buy one of our egr replacement pipes, as Chris' post states, the SFS kit fits better with our pipe and stops the silicone pipe rubbing on the brake res.
jabbasport
They're £49 inc vat i believe...
I'll fit it for £12 inc vat, that also includes mapping out the EGR error aswell :)
Take note though, we're currently out of pipe and expect some to be in within the next week.
Funkyfin2000
Oct 6, 2005
2,477
Ok mate, thats cracking, i may well pop down on a Saturday morning sometime to get one done....
your a little bit away from me, but would make a nice trip out one Saturday with the dog :D
cheshire cat
1,813
cheshire
Visit site
I wouldnt have thought so, there's no need for it to operate on idle.
It'd be interesting to find out for sure though by taking some readings :)
already done, there is a signal at each gearchange but it is so brief it can't build vac fast enough to move the valve:confused: so god knows why it does p.s. no opperation at idle
slick
Bit of an animal
Mar 15, 2005
1,124
Essex
Thanks for your input, that saves me plugging up the vac pipe to test it.
Strange that at gear changes it operates!?
Glad no change at idle and tested for it, that means my EGR mod will work no problems when i remove the EGR codes
Kev, do you remove the code using Vagcom then?
Funkyfin2000
Oct 6, 2005
2,477
Right dudes, ive done some logging....would anyone care to make some comment...on first look it looks like i get less boost than Chris.....which doesn't sounds good :(
Check it out and see what you think!
4th gear from about 1500rpm....no errors logged and with EGR blanked....
Block 003
Time Engine MAF MAF EGR
Spec Speed Specfied Actual Duty Cycle
0.01 1449 850 901.6 4.8
0.8 1533 850 989.8 4.8
1.62 1659 850 965.3 4.8
2.44 1764 850 940.8 4.8
3.22 1869 850 989.8 4.8
4.04 1995 850 1097.6 4.8
4.84 2121 850 1122.1 4.8
5.64 2268 850 1200.5 4.8
6.42 2415 850 1244.6 4.8
7.22 2562 850 1249.5 4.8
8.04 2730 850 1249.5 4.8
8.85 2856 850 1239.7 4.8
9.66 3003 850 1234.8 4.8
10.49 3150 850 1215.2 4.8
11.3 3276 850 1210.3 4.8
12.1 3402 850 1200.5 4.8
12.9 3507 850 1195.6 4.8
13.7 3612 850 1185.8 4.8
14.5 3717 850 1176 4.8
15.3 3822 850 1156.4 4.8
16.1 3906 850 1156.4 4.8
16.9 4011 850 1122.1 4.8
17.7 4095 850 1117.2 4.8
18.5 4053 850 1097.6 4.8
19.3 3990 850 445.9 4.8
20.1 3822 850 450.8 4.8
Block 011
Time Engine Spec Intake Actual Intake D.Cycle
Stamp Speed Pressure Pressure Map
0.4 1491 1884 1944 42.2
1.22 1596 2004 2124 49.4
2.02 1701 2136 2100 48.2
2.82 1806 2244 2064 49.4
3.64 1932 2340 2160 49.8
4.44 2079 2388 2352 54.6
5.24 2205 2436 2460 58.2
6.02 2331 2460 2532 61.4
6.82 2478 2472 2592 64.1
7.62 2646 2484 2592 66.5
8.44 2793 2472 2556 68.9
9.26 2940 2484 2532 70.9
10.06 3087 2484 2520 72.5
10.89 3213 2484 2508 74.1
11.7 3339 2484 2508 76.5
12.5 3444 2484 2520 78.1
13.3 3549 2472 2544 80.9
14.1 3675 2460 2580 84.1
14.9 3780 2460 2604 86.9
15.7 3864 2448 2616 90
16.5 3969 2436 2604 92
17.3 4032 2424 2592 94.4
18.1 4116 2400 2556 94.4
18.9 4053 1116 1548 49.4
19.7 3906 1104 1212 48.6
20.5 3738 1080 1212 48.2
I also did a second run, so please take a look...
Block 003
0.4 2163 550 700.7 84.5
1.98 2352 850 1225 4.8
2.78 2541 850 1239.7 4.8
3.6 2730 850 1249.5 4.8
4.4 2940 850 1239.7 4.8
5.21 3150 850 1205.4 4.8
6.04 3360 850 1185.8 4.8
6.84 3549 850 1141.7 4.8
7.64 3738 850 1127 4.8
8.45 3885 850 1097.6 4.8
9.26 3990 850 1087.8 4.8
10.06 4095 850 1073.1 4.8
10.86 4200 850 1053.5 4.8
11.66 4263 850 1033.9 4.8
12.44 4347 850 1004.5 4.8
13.26 4410 850 989.8 4.8
14.06 4473 850 960.4 4.8
14.86 4536 850 955.5 4.8
15.64 4578 850 935.9 4.8
16.47 4641 850 906.5 4.8
17.28 4683 850 896.7 4.8
18.08 4704 850 896.7 4.8
18.88 4767 850 891.8 4.8
19.68 4704 850 578.2 4.8
20.5 3171 325 573.3 4.8
Block 011
0.01 2142 1584 1620 45
1.59 2268 2448 2256 62.6
2.38 2436 2472 2520 63.4
3.2 2625 2472 2532 65.3
4.01 2835 2472 2544 68.9
4.81 3045 2472 2508 71.3
5.62 3255 2472 2472 72.5
6.45 3465 2472 2448 73.7
7.24 3654 2460 2460 75.3
8.05 3801 2448 2472 77.7
8.86 3948 2436 2472 79.7
9.66 4053 2412 2460 80.9
10.46 4137 2388 2424 81.3
11.26 4242 2364 2388 82.5
12.06 4305 2340 2376 83.3
12.84 4389 2328 2340 82.5
13.66 4452 2304 2304 82.1
14.46 4515 2280 2268 80.9
15.26 4578 2280 2232 79.3
16.04 4599 2280 2196 76.5
16.87 4641 2280 2148 72.9
17.68 4704 2280 2136 71.7
18.48 4725 2280 2136 69.7
19.28 4767 2268 2148 68.9
20.08 4011 1104 1704 49.4
There ya go!!!!
What does my MAF look like? Knacered or alright?
