Blitz.
Hi all,
I have a very loud and obvious knocking noise on my Ibiza 1.4s (sounds like 2 hammers banging against each other, under the bonnet area i think),
It started happening about a month ago now, as soon as i heard it i took it to a garage, they told me it was the drive shaft, so i had that replaced with a new engine mount too, then about a week and half later the noise came back again, so i took it back to the same garage, they checked it for me, but everything seemed fine, now the noise keeps coming & going constantly, it doesnt make the noise while the car is station, but as soon as i move off the noise gradually picks up, depending on the revs, but the car still feels like it drives fine.
Does anybody here know what the problem could be?
Thanks in advance :)
Thanks for the reply mate, i know for deffo that either 1 or both rear wheel bearings need greasing, the previous owner said, i had a part of the exhaust done about 2 months ago due to it snapping off in the engine area tut lol, and as soon as i drove off after getting the pipe done about 5 miles or so, the heatshield split or something, made the car sound really loud, but that was a different noise to the one now though mate, & yes it is lowed by 60. just before i got the passenger side drive shaft sorted (when the noise first began) the mechanic told me it was the drive shaft, but it still does it, you think it could be a faulty drive shaft or something ?
if youve been running a bearing unlubricated, i would just replace the component as it will cause you further problems soon enough.
sounds like i has when i had a problem with my exhaust. dont know what was loose but as i speeded up it use to BANG BANG BANG....something was loose somewhere.
my exhaust is leaking at manifold and downpipe due to the head bolts not sticking out far enough to get a bolt on lol, and exhaust is also nocking in 2 places due to perished exhaust brackets, only does it at idle though
hi mate, so you think it has something to do with my exhaust aswell then ? i actually thought it came from the engine area though lol, but cant really tell cause it only comes on when im driving.
yeah my noise is like bang bang bang lol, it also sounds like a horse hoof stepping when i listened closeley to it.
might be a different nocking noise, i just no mines the exhaust lol, just saying you should check all the mounts though and make sure it isnt your exhaust.
got the car back today. had new exhaust clamps and rubbers fitted and its sorted :)
mine also needed a wheel bearing replaced.
thanks mate, appriciate for letting me know, how much did that cost you if you dont mind me asking mate, and so do you think the problem i have at the moment sounds like the things you said then, thanks alot :)
