I've recently had the car rr'd and the torque was over 300 lb/ft.
Initially, I was pleased with the results but 'if' the figures are anywhere near accurate, I'm becoming a little concerned over this torque figure.
Should I be worried about the rods (they're standard)?
I'm now wondering if I should get the boost turned down a smidge as it hits 25psi which seems high. I know it's just a quick'ish peak but from what I've read on here that's what puts the most amount of strain on the rods. What sort of torque levels are safe, bearing in mind the way the turbo cuts in ie loads of boost/power all at once?
Car is running K03s.
