part numbers need plz..
May 16, 2008
506
southampton
hi i need the part number oe for the leon cupra r charge pipe that goes around the engine and also the engine cover bit in front of the dip stick the little gray bit please..:D
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
using a 2004 Leon with AMK/BAM engine
06a 145 731 M for the pipe
06a 119 518 L for the small cover
gimme 5 ill get pics to confirm it
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
#25 for the pipe
i'd show the cover too but etka has a better pic than vagcat is using
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
i guessed it was to setup some trick FMIC or along those lines
as to it fitting - i would check around here to be sure as it doesn't ring a bell
get dealer to make sure numbers are current too as my system isn't allowed updates :(
