take the engine cover off and you'l find standard black valve at the back on the right hand side. only a small thing but you jus unscrew the hoses and put the 007 one on. id recommend puttin it on in the same position as you take the original off but some people put it on sideways. no benefit doin it that way as far as im aware. i stand to be corrected, but my set up is fine.
ps - whilst fitting disconnect battery to reset ecu.
Yes it will. I have one with my standard DV and it's pretty loud, I am also only running standard boost. A 007 with an open cone will be a little louder than mine is.
