FK coilovers (no go)
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
You werent kidding sooty - they literally DID explode!
My FK's aren't ageing too well either. Paint's already coming off the springs, the "protective coating" lasted no time at all and the bloody things have started pinging again! Don't even know what causes it. Tbh I'm not worried about that atm - just want my turbo (and the f**king rattle in the back of my car) sorted first!
Altech
Ibiza PD170
Oct 3, 2007
1,996
London
id take them off yea cant really get acess unless theyre out :)
Could'nt the adjuster be dropped right down and some copper grease applied? Or maybe compress the top spring slightly?
I made sure I put plenty of copper grease on my topmounts after reading a thread on here.
Aimez
Oh dear I am not very put of buying coilovers thanks guys!! You have to strip them every month!? Who actually has no life and so much time they can do this?!
I don't even wash the car once a month and I am not confident mechanically to fit these myself let alone take them apart all the time and then pay god knows how much to have the alignment done every time!
fr-tdi
Detailing freak!
Feb 7, 2008
853
fife, scotland
you dont have to - but expect problems like this post for example.
i usually stripped my coils once a month when i had them and they lasted on four cars.
the coils for my ibiza never saw copper grease or sealant - i only bought them to lower the car while the air-ride was being made.
washing your car once a month is a cardinal sin. you should hang yor head in shame :(
Altech
Ibiza PD170
Oct 3, 2007
1,996
London
Nope no mechanic mates, I'm the mechanical one out of my mates but don't have the machinery to do it. I only paid £35 to have it done yesterday.
Gazb
328
Lisburn, Northern Ireland
only a few pics of new coilovers fitted (it started raining)
i have found the ride is so much smoother, the front seems to drop so much! the rear doesnt go no where near as low as the front but i set the rear almost as low as it would go and just made the front match, i guess the springs may settle a little so it is slightly high at the front but wil see with time what happens. hope this is useful to anyone thinking about buying fk coilovers (or maybe i just had a bad set) and always remember most the time you get what you pay for!
The bracket that the drop link is bolted to seems very flimsy in comparison to the setup on the FK's.
Are they that shape so that you can use the standard drop links with the Weitec's?
sooty22
sooty22
Dec 28, 2006
726
nera richmond north yorks
i have checked the tires etc and all are ok and yes my abs has been working an tcs like all the time! i dont peronaly thin you should have to remove and clean the shocks regardless of cost/make all the time they should be built well enough to just need a clean every now and again. i cleaned mine and greases the threads every rew months but that still didnt stop the passenger side popping and the leaking on the drivers side
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
I agree with that. You pay enough for the damn things, they should be a bit harder wearing. OEM suspension is so why shouldn't coilovers be?
I clean my coilovers up every now and then too but shouldn't have to keep on top of them every week!
sooty22
sooty22
Dec 28, 2006
726
the bracket is actualy the same thickness as the ones on the fk's maybe just a unclear pic. i know there s a lot of weight on the front of the derv ibiza especialy and they do taks some stick but i have noticed when ordering that the same coilovers apply for all the range from a 1.2 to the derv and wonder if they were not up to the task of weight issues on the front end? the rears are fine not a problem at all with them.
Mar 8, 2007
831
You dont need to remove them or even remove the wheel to clean them or adjust them, just jack the suspension up, get an old tooth brush some soapy water and some non-abrasive cleaner and just clean away gently, then move the adjusters down a couple of threads and back up, apply some grease, repeat.
Just do this every couple of months should only take an hour.
