Mar 1, 2009
1,079
Liverpool
Noticed this last night.
When pressing on the brake pedal, I get a clicking noise from the driver side brake caliper, I can feel it through the pedal also.
Its whenever it gets to a certain point on the pedal, it clicks every time.
Anyone else experienced the same?
I'll trade your clicking for my sqeeking ones
Well embarrasing, I bet i could play a song like a violin with my brakes
The disks are hardly worn in, and the pads have a fair bit of meat left on them.
Will give them a strip and a clean.
To be honest, im not impressed with the Brembo's ...
On my fiesta iv got the 300mm conversion from the mondeo, they are **** hot.
Even when taking into consideration the ibiza is heavier, I was quite shocked...
Im not thinking their braking as they should, so im going to be stripping them right down.
the clicking noise could be the pads moving forwards and backwards, if you look at the pads on bembo brakes the holes are not round where the pins go through to hold the pads to the caplier the holes are elongated, that allows the pads to silde and cause this knocking, best fix is just strip and clean
working brembo's will plant your face in the windscreen, more so with decent ds2500 pads/hoses
My brembo's definitely aint working properly then!! To be honest the brakes in my mates bog standard VW Passat feel 10 times better. I can barely make my girlfriends handbag fall off the back seats if i lock on the brakes at 40mph. :(
Anyone got any ideas what could be causing this?
not bled the brake lines properly ?
Sounds like there galzed tbh. Isn't sqeeking a trate of pooring bedding in procedures
my brembos have bin pants since i put them on, my gfs nissan micra has better brakes than my car!! ive done everything to make them better cleaned them changed pads discs changed the seals and dust covers still no good!!
My mate at Audi did a full brake fluid service and it has made absolutely no difference. :(
Could this problem be due to a lack of servo assist due to the following problem?:
http://www.seatcupra.net/forums/showthread.php?t=51097
My car has not been recalled but this could be due to the fact that it was an import and/or that it now has a private plate. Im not sure whether its worth giving Seat my chassis number so they can check if this needs changing. :shrug:
