Quick update guys,
Well the block is getting re-honed, new piston rings, new guides etc etc.. the guy who done it before was totally incompetant, put in the right parts but not the right way!
I have THS rods so going for Pauter now and the girdle to keep things secure down there!
I have managed to get a n/a cam from a 97 a4 1.8 20v (£45!) so will be good to see the difference... if any!
Also ordered a sigma short shifter and N2MB WOT box with 2 step... I cant afford racelogic.
And for turbo im getting owens gt3076r but with 0.63a/r, my 3071r was not in good shape anyway, the blades suffered bad contamination.. stupid HKS filter, and there was not side to side play but back to front - if you are holding both wheels with your hand... so got a quote and it was £650 + vat!! I'd rather scrap it!
Hoping everything will be here and running in 2 weeks, back to mapping, then to a DD dyno to see the gains and hope they were worth it!
I have just installed a wot box, havent had a chance to test it yet but I am racing at York raceway on easter sun/mon so will get to use it in anger than.
You'll love the wot box, i have it on my car and its awesome.
Good luck with the rebuild, hope it goes well. :D
Hope things go well for you mate,you deserve it.
Cheers guys I feel like I deserve it too!
But I must say the only reason i;ve got this far with my car is because of you SCN forum members and all the replies and opinions you have all given me...
Very much appreciated :)
easy to do?
Yeah pretty simple, just 2 wire to join into the ignition leads, 1 wire to connect to a injector, 1 for the TPS and 1 for a clutch switch. You will have cruise control so its easy I had to make a clutch switch which took a bit of time.
You could easily do it in a couple of hours.
hmmm.. I just ordered the 76r with 0.82 backhousing!
Is that a bad idea considering my rev limit will be 7300?
I went for it because owens say that for some reason with the 1.8t's it doesnt lose much low down if you go for 0.82 over the 0.63.. i hope thats the case!
I still have today to change my mind so please tell me anyone if you think I should get the 0.63 housing instead..
Thanks!
this is what they told me and as per my email to you I dont find that there is much more lag than my old turbo.
You know what its like you soon get used to the extra power and if I had gone for the .63 housing I would have wished I had gone for the .82.
Why 7300 rpm limit ?
I know that feeling all too well!!
I am going for 7300 as I have supertech valves but standard springs and retainers, and I can only see 6k on my dash with standard clocks, so I thought if its at 7300 I am safe and can go to 7300 without worrying...
Think its too low?
It was at 8200 before so I could never drive properly i was too scared!!
