enigma
109
whats the maximum top speed for a 1.9 Tdi in first gear at full revs running 175bhp and 306lbs
Depends on the gear ratio... can you be more specific? What car is it?
Power / torque will have no effect on 1st gear top speed, the speed is limited by the gear ratio... only difference is, more power / torque will get you there quicker.
im asking as i get around 20mph in first and first gear seems to run out very quickly and i was concerned it was due to clutch slip , however i dont get symptoms of clutch slip in say 4th or 5th could it just be first or just that 1st gear is just short ?
agreed the first gear in a diesel is much shorter than in a petrol
i have a pd150 and 1st is very short as in most diesels
stu
Mine will pull 30mph I am sure. Will just nudge 60 in 2nd. Gears are not short its just low revs. If its 6mph/1000rpm then a petrol engine at 7000rpm would be 42 mph. My old corolla t sport would crack 40 in 1st at 8200rpm.
I thought this was one of the first April Fools pranks of the day. Done at the stroke of midnight
With my old 5 speed setup it was roughly
1st gear 30mph
2nd gear 55mph
3rd gear 80mph
4th gear 105mph
5th gear 130mph (it would never go to 5000rpm obviously)
corolla tsports are ace, i fancy one next. dont you miss the "lift"?
i'd have said the opposite, having had a tdi box until recently i found it Very long geared and diff ratio'd compared to a petrol setup
might just seem that way due to the way a tdi operates
I do miss the lift and the reliabillity. But I would miss the performance of a 220 odd hp leon which will do 60 to 100 in 8 seconds!:headhurt: The corolla took about 12 iirc. Also the fuel economy on the tsport does not compare to the leon 25 versus 45, could not afford to run a tsport now:cry:
