johno
Conflicting evidence out there regarding recommended service life of PD timing belts. Autodata recommend 40k miles or 4 years, Tecdoc data supplied by Contitech (who are OE supplier of belt to VAG) recommend 90,000kms. Word on the street suggests VAG have bulletined dealers to change at 40k miles or 4 years. Local dealer says 4 years or 60k miles, local VAG specialist also says 60k miles or 4 years.
Any factual evidence not hearsay appreciated!!
thanks for the info, car is due for major service @ 55k so will get it done then; and replace the water pump as well!
cheers johno
iv got a 2004 tdi 130 and my service book says that the timing belt only needs changing after 80000 miles now after reading this and the fact that my car has done about 59k and is four years old does this mean that i should have the timing belt replaced or not as the book states 80k but has no mention of timescale at all?????
mine is an 04 tdi 150 just done 74k and has no history of a belt change should i get it done now - and what can i expect to pay for the job?
belt change interval
Change period is definately 60k or 4 years. Fit new water pump as well, VW also do exchange pumps (just as good and with full VW guarantee) and cost about £35 exchange. ICME labour time is 2.9 hrs for changing the belt/tensioners so 3 and a bit hours should cover it. Don't scrimp, if it aint done right the engine damage will make you wish you'd paid to have it done properly!!
Cheapest VAG dealership to use is Skoda, I'm not proud! Besides running Seats we also have Skodas in the family.
Had my 54 plate leon fr tdi serviced in January.
62000 miles, cam belt, tensioners & water pump replaced.
service - £120
cam belt etc - £299 (vag approved specialist)
Just coming up to my 60K service too, so far havn't a quote under £520 for the service and the belt change, that dousn't include water pump either! If you see a kidney in the for sale section, its mine :(
Yeah, its worth shopping around, I usually go local for convenience. It would be a git to get stuck without the car 100's of miles from home if something unexpected were to come up.
booked in with specialist vag garage for tuesday replacing the water pump same time £300ish inc vat
Hi I was quoted £600 from Seat dealer in South London this did not include the water pump when I complained at the pump being extra they said we will throw it in .
I got a quote from a local garage for £285 including water pump But told me that these belts last for 70k miles but they would take my money if I insisted. Flagging up changing the belts so early may have been an added value ploy by some one at Seat.
Nobody at seat would coment but just repeated a mantra saying it was policy.:censored:[:@]
