Empi5
Your scaring me.......
Feb 24, 2005
2,806
Staffordshire
Help please.
2005 LCR
When cold, no boost ( boost gauge fitted ) and it flutters when you lift off, after about 10 minutes driving, the boost returns and the flutter goes..
VAG COM shows no faults.
Split R fitted.
Any suggestions. ?
Phil I will see if I can find my original OEM valve and as I said last night I will swap it out for you at Thruxton.
If that cures it we can then service you split R valve.
Oh by the way I need copious amounts of beer when I’m working on other peoples cars. ;)
Where's your fluttery gauge plumbed into?
Hmmmmm if i knew that id actually know what im talking about, Unfortunatly i didnt install it, but i know for sure its no where near the FPR, its a very discreet install done by JBS.
If they have taken the feed for the boost gauge of the top of the Splt-R this will cause you problems.
Have you tryed turning the top a couple of clicks ???
I had a prob like this.
My boost was fine just the split r fluttering all the time! No matter what I did with the valve (tighten/loosen) it just kept happening.
Sent it back to Forge on Mon and got my replacement 007p today:D:D:D:D.
Very, very, very happy!
Had the boost gauge fitted for nearly 4 years, split r for 18 months, problem has only just started happening.
