Ovni_cupraR
Yellow Peril
Oct 25, 2008
131
Maidstone, Kent
I don't know if it was because of the all the rain we've had tonight but my car felt much quicker! I was beginning to worry, as I only bought it last week and it felt rapid the day I got it, but the last 3-4 days its feels like it might be a bit down on power, either that or I'm just getting used to it? My mate has a golf gti (150bhp) and it doesn't feel much quicker than that to be honest (except tonight lol)
scott
the intercoolers like the wet as they are more efficient then + in the wet ure tires slip faster so u think u have more power.
but then when you plug it back in..turn your ignition so all the lights on the dash comes on, and wait for the quiet beep in your engine bay to finish, then start your car
Hey Scott,
I live in Tonbridge do you know anyone else with Cupras/Seats as I go Maidstone quite a bit be good to know of other local enthusiasts?
Matt
Hey Scott,
Matt
I've got a mate who drives an ibiza tdi, apart from that I've only seen one member of this forum around maidstone, he's got a black LCR with diamond cut wheels, cupragav i think his forum name is
And if you still have original OEM headunit, don't forget to dig out your radio code beforehand also :)
Forgot to do that! I had to drive around earlier in silence lol
I disconnected the negative terminal for half hour, then re-connected it and turned the ignition on so the lights on the dash came on like you said, and waited about 3-4 minutes but I don't think I waited until that quiet constant beeping sound stopped, does that affect the reset?
scott
Im from medway and sometimes venture down to maidstone of an evening ;)
Try it again to be sure. When you switch it back on leave the bonnet open and leave the driver door open and wait for the high pitches noise to stop then just start the car as normal.
High atmopheric pressure effect the performance of the car as does ambiant temperature.
I find really cold foggy mornings is where my car is at its best and damp drizzely days.
Try givinbg your SMIC of FMIC a good soaking with a cold hose, that usually revives my motor.
Also a thermal spacer like a Phenolic gasket helps to stop the heat transfer between the block and the metal intake manifold which can heat up the previously cooled boost pressure
I'll give it another go in a minute. Although I'm beginning to wish I never did it in the first place as the previous owner didn't give me the radio code and it's locked out now, I just rang my loacal seat garage and they want £45 to get the code! I might as well get another head unit :blink:
