Went to fit coilovers...can someone help me?
Hi guys,
Went to fit my coilovers today with a few mates. Were all reasonably handy with the spanners and have changed bits and pieces before.
I was following DPJ's guide but it doesn't say how he got the existing suspension off in the first place (at least I think it doesn't?!)
I undid the ARB droplink bolt (bottom), the strut housing bolt, the track rod end and the 3 bolts underneath the disc (in a triangle shape, attached to a ball joint but I'm unsure of the name). We got the strut free (with disc and brembos still attached) but obviously it was still attached to the driveshaft and at the top of the strut so there was little in the way of movement available.
Can anybody give me some advice on where I may have gone wrong or point me in the direction of another guide? I really want to get it sorted but am at a loss as to what I'm doing wrong. We've fitted coilovers to a 206 GTI and C2 GT before, but obviously the LCR is a different kettle of fish :(
Cheers, Alex.
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
you dont need to undo the wishbone/balljoint end, or the track rod end at all to remove struts...
did you use a hub splitter/cold chisel to split the hub before you tried to free the strut??
did you get the top nut undone in the strut turret?
to remove old struts
1. undo bolt into wheel bearing housing.
2. undo top nut in engine bay
3. use hub splitter to split the wheel bearing housing.
4. undo arb link into wishbone.
5. strut will now come free, if not use a rubber mallet to push it upwards and out of the hub.
drivers side is harder as youll have less room as the hub doesnt drop as far.
same procedure, you may need to compress the springs on this side whilst still intact to get some room to remove
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
lcr is the same as the 206, i have both and they are pretty much the same,
i think you need to take it to a garage, you dont need to remove the track rod end or the ball joint,
jack car up front only both sides, ( relives pressure on arb)
undo the top drop link nut.
undo bolt holding shocker to hub,
push hub down, shocker is out hub
undo the top mount nut
remove shocker
strip old suspension and use top mount for coils if not buy new
then refit.
it takes about an hour and a half to do coilies on a leon.
james walker
May 24, 2007
5,121
retford notts
remember the hub splitting rik, this could be why they cant get it out tbh.
vw use a proper tool for this, laser tools sell them and its a godsend.
then refit.
james walker
May 24, 2007
5,121
retford notts
no real need to remove wishbone bolts though is there dpj??
also, why the need to strip the hub, just to give you more room?
i did neither and it was a simles job tbh.
Ah ok, so track rod ends don't need doing. So it's most likely the shock to hub bolt is seized/rusted and needs opening up.
As for tracking, I'm having new tired on soon (next week) and am having full 4 wheel alignment and geometry set up at a VAG specialist.
james walker
May 24, 2007
5,121
retford notts
what did you use to seperate them? it isnt that big a gap so a small cold chisel will work, but theres nothing like having the right tools
they dont need moving much tbh.
but if youve tried and then undone ball joints and track rod ends then i dont know where youre going with this one tbh mate....
really is 3 bolts and a hub split then its out, no need for disc, caliper removal... id try some anti seize on the hub aswell.]]
james walker
May 24, 2007
5,121
retford notts
yeah easier than taking track rod ends off.....
i think back to basics prep and ensuring right tools are to hand is the winner on this one?
Right, will go out now and spray some stuff on the hub, then will have a go tomorrow. I'll probably get a couple of chisels on it
Thanks for the quick help, I've had a crap couple of hours trying to figure it out! As I've said, I'm not too bad at doing things myself, just stumped me that the hub wouldn't move at all!
Alex.
james walker
May 24, 2007
5,121
retford notts
wouldnt move which way, to split?
you wont get 2 chisels in it mate. id seriously suggest getting the hub splitter, makes life much easier next time aswell.
Lol, just re read that last post, by 2 chisels I mean I'll go and buy a couple of new chisels to use!
And as for the mounts etc, that's the annoying thing. I've bought all the bolts, new top mounts, bearings to replace all oem stuff, doh!
I love this forum, I've been a member of plenty of other owner club specific sites but none compare to this in terms of help and speed! :)
