tarzan
cupra owner from norway
Mar 15, 2008
1,122
drammen norway
after i lowered my car my driveshaft looks like this haven`t hade 4 wheel aligment yet so i hopei will look better after that
the left drive shaft
this how low the car is
It looks better than mine at the moment.....
Mine popped and the inner cv is in 39 bits :(
looks like that's from above and they do lean rearwards a little anyway, that does look a little more than usual though
have the 2 pics been taken at same time ?
yes its from above and pictures are taken at same time.i just mounted fk coilovers on it.
hope it gets i little better when the garage have adjusted the camber and the rest
suspension is new. whats the easiest way to find out if the engine mount i broken
you will need a friend to help you out open the bonnet, start the engine and with the handbrake on hard try and pull away (without doing so) and get your friend to watch your engine as you do this if there is a lot of flex then this is your problem
Could be a broken engine mount. You could try doing what Lemon describes. Let me know if you´ll need a spare mount.
Prebs
